07' sportsman 700 power loss?
Old Dec 14, 2008 | 02:01 PM
dodge33's Avatar
Default 07' sportsman 700 power loss?
short story, i put a new winch and plow on and smashed a wire causing a short and fuse to blow. i found short and fixed, now i am only getting a maximum of 4500 rpm in high range? it is like it isn;t gettting power for some reason? any ideas?
Old Dec 14, 2008 | 02:14 PM
Koerbs's Avatar
I would say your short damaged the computer..... try holding in the override button to see if it goes away....
Old Dec 14, 2008 | 02:22 PM
dodge33's Avatar
do i hold the override with it started?
Old Dec 14, 2008 | 02:29 PM
Koerbs's Avatar
Push it when it cuts out.
Old Dec 14, 2008 | 02:43 PM
dodge33's Avatar
it doesn't cut out........so push it when i have the throttle at full speed and see if the rpms go higher? could it be the ecu that would be bad?
Old Dec 14, 2008 | 09:29 PM
dodge33's Avatar
i tried the override but it didn't really seem to do anything! i guess i am going to have to take her into a dealer or something. Thats SUCKS!!!!!![img]i/expressions/face-icon-small-frown.gif[/img] well. i guess i will try a few more things before i have to pay them a tone of money i am sure to get them to look at it. thanks!
Old Dec 14, 2008 | 09:41 PM
700 sportsman's Avatar
dodge, heres the link, to the service manual, may help your troubleshooting
Old Dec 15, 2008 | 12:05 AM
dodge33's Avatar
thanks for the link.......i bought a service manual (cd) off ebay......the cd was like $15, they want like $50 plus for the paper manual! i think that is rediculouse! thanks!
Old Dec 15, 2008 | 07:38 PM
dodge33's Avatar
so i did some more research..........i replaced the spark plugs first...the cheapest solution. That didn't do it bhut now i have brand new spark plugs!
I checked the spark ignition coil and it definitely was it. When i took it off, i smelt the same electrical smell i smelt before the 20 amp fuse blew!
So to anyone that reads this. DO NOT EVER USE A LARGER FUSE! the amp fuse that the factory calls for is the max recommended! I tried a fuse that was only 5amp larger and i fried my ignition coil! Life stinks............get over it right!
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
