No Spark on 500 sportsman
Old Dec 14, 2008 | 07:48 PM
Mud Runner 's Avatar
Default No Spark on 500 sportsman
First i'd like to say nice site. I was plowing snow with my 1999 500 Sportsman 500 and it died. After some basic troubleshooting I decided to check for spark. No spark tried a new plug same result. I did notice that the wire on the temp sensor is broke off. Does this have anything to do with lack of spark? How do I check the coil? How can i check the Magneto?
Thansk for the advise
Old Dec 14, 2008 | 08:31 PM
Temp wire wont have any thing to do about no fire. Check red and red/white wire leading to cdi from stator,should be about 97 ohms + or - 20%,also check red and red/black(I believe) connector,should be about 440 ohms + or - 20%,this should eliminate stator,also can disconnect black wire first from cdi and check for fire(if has spark could be short in kill switch OR not very frequently can be partial short in cdi (but not often as I've said). Also pull plug cap from wire,check for spark(5000 ohm caps can sometimes go bad also)
Old Dec 14, 2008 | 10:39 PM
Thanks for the info. I went to push it to the shed and it started. I drove it into the shed it died again. I think the kill switch may be the culprit. I will check the contacts on that. Have yoiu seen coils act like this?
Old Dec 15, 2008 | 02:16 AM
Disconnect black wire first and see if runs ok,this eliminates kill system
Old Dec 15, 2008 | 08:00 AM
Where is the black wire located?
Old Dec 15, 2008 | 06:31 PM
Single black wire out of cdi,unplug!
Old Dec 18, 2008 | 09:16 AM
Thanks for the help. It was the key switch. In the run position the reading would go from open to ground to about 15 Ohms. Took apart the switch works now.
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
