Starter
Old Dec 16, 2008 | 08:17 AM
trailmaster500's Avatar
Default Starter
How do you get at and remove the electric starter owner manuel is useless to me the starter just clicks the quad has been sitting for 2 years starts right up by pull start but i want the electric to work also the reverse has stopped working it engages but it acts like its in neutral i only paid 600 for it so i expected a few problems thanks for any help.
Old Dec 16, 2008 | 09:22 AM
eggenz7's Avatar
Default Starter
to remove the starter you need to pull the recoil housing off that will reveal 2 bolts in the bottom left hand cornor. remove those. then there is a support bracket on the rear of the starter. two bolts here. you need to have patience for these two because you can only get about 1/4 turn each time. for me is easier to remove the seat and airbox to get at those bolts but for some reason they never make it back in [img]i/expressions/face-icon-small-smile.gif[/img].
on the reverse i would check the gear oil in the gear box to see if theres any metal shavings/chuncks. if not then an adjustment may be nessecary with the linkage rod. remove the rod from the bell housing on the gear box and see if when you change gears there is it will go into reverse.
theres not much in those gear boxes to go wrong.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
