TTR 125 idle problems
Old Dec 17, 2008 | 06:57 PM
chikester's Avatar
Default TTR 125 idle problems
2006 TTR 125 is having problems idleing. The choke plunger was corroded so I replaced and cleaned carburator while I was at it. The bike will start okay but I cannot get it to idle well at all. Adjusting the idle screw does a little good but not much. I noticed another adjustment screw inside the bowl but not sure if this would have anything to do with it. Any help would be greatly appreciated.
Old Dec 18, 2008 | 09:36 AM
ROBBASS's Avatar
First I would pull the bowl back of the bottom of the carb and remove the front pilot jet, take one single strand from a wire brush and slide it through the hole and make sure that it is not plugged, that is what will or will not let your bike idle is the pilot jet, if that doesnt work, your valves may need to be adjusted.
Old Dec 18, 2008 | 09:57 AM
chikester's Avatar
which pilot jet? Isn't there two of them inside the bowl? Thanks.
Old Jan 6, 2009 | 05:08 PM
chikester's Avatar
does anyone know if the pilot jet inside the bowl is suppose to be screwed all the way in or do you turn it back a couple turns?
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
