2003 Wolverine 350 shifting troubles
Old Dec 19, 2008 | 08:56 PM
jakeowens's Avatar
Default 2003 Wolverine 350 shifting troubles
Recently my 2003 350 wolverine has started acting up.
I have a really hard time getting it to shift into neutral, and recently it won't hardly go into neutral at all. I also have trouble shifting up through gears, it may take 2-3 hard pushes/pulls to get it to shift, its particularly noticeable in the lower gears. Most of the gears it shifts through fine, its just going from reverse-neutral-first that I have lots of problems.
Also, when I'm in first and shift down, it will either stay in first, or will shift into reverse automatically, without twisting the reverse button. Likewise when i shift up from reverse, it goes straight to first.
Also, when its running, its darn near impossible to get it to shift into/out of reverse. I have to shut off the engine, then shift, at which point it shifts fine and I restart it.
Any suggestions? I'm hoping this can be fixed by adjusting the clutch, but want to know which way it needs to go.
Other then these shifting problems it runs great, full power in all gears
Thanks
Old Dec 20, 2008 | 01:51 AM
toddmh's Avatar
the older 350's see this problem allot ..You need to adjust your reverse cable,mine was always a pain to find neutral..
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
