4x4 not working in forward olny reverse
Hey,
My 4X4 will only work in reverse, it works perfect in reverse, when i put it into gear to go forwards, no light no nothing. I have just replaced my rear anxle on the left side? 4X4 was working perfect prior to the anxle being replaced. Any suggestions on what to do? Thanks
1998 Polaris Sportman 500
Rear driveshaft wont have any thing to do with awd,probably selector switch in shift box responsible for no awd in forward especially if awd light not on. Try low range also and PUSH a little harder on shift lever,if awd lights up then switch worn. Switch can wear and not make full contact usually in hi range (most people use this the most) in low makes better contact,reverse almost never a problem.Part of it is switch wear and possible internal shift box lever wear at the same time. I have had a bunch of these over the years. Good Luck
<div class="FTQUOTE"><begin quote>Originally posted by: bmack
sill not coming on</end quote></div>
Probably switch!! Can have reverse but not forward when switch worn.
is it a eazy fix? how much is a new one? is there a way to get around it</end quote></div>
Must take shift box apart,have to be a little careful since has spring pressure. You will see switch,replace with redesigned switch follow wires into terminal board rehook up,good time to change oil also,fill to where oil barely covering internal shift arms(on the older models 5-30/10-40 sufficent
bzdok1234
30
Feb 23, 2016 01:55 PM
