Polaris 400 sport
Old Dec 20, 2008 | 11:27 PM
snupills's Avatar
Default Polaris 400 sport
1999 polaris 400 sport...reverse has not worked on this in forever. (automatic) started tryed to put in reverse and for no reason it died...would not start back up. the started is mangled, removed it...still will not pull start..the fly wheel is not turning at all......any suggestions????
Old Dec 21, 2008 | 09:58 AM
eggenz7's Avatar
the reverse is probably caused by a maladjustment on the shift linkage.
if the recoil doesnt turn the flywheel i would take the recoil housing off and see what is stuck shut on the recoil part or if the basket or cogs are still on the fly wheel.
Old Dec 21, 2008 | 10:33 AM
ftwflh's Avatar
Unplug the reverse limiter wire.Should be under the hood and has 3 wires.I think it is a black wire just unplug it.Or you can get a new Rev box they run in the $70 range
Old Dec 21, 2008 | 11:05 AM
scrambler400enoge's Avatar
Shapeshifter Rider
Clean and rebuild the carb I lost reverse and got it back by doing that.
Cole Hadden
Jun 15, 2025 09:05 AM
RickyMac
Mar 5, 2016 07:27 AM
1988josh
Ask the Editor
Jul 16, 2015 09:43 PM
John Boy
Jul 13, 2015 11:16 AM
black_thunder
Jul 9, 2015 05:58 PM
