99 scrambler 500 carb question
Old Dec 21, 2008 | 06:21 PM
1130all's Avatar
Default 99 scrambler 500 carb question
i would like to know what the air/fuel screw would set on.thanks for any help
Old Dec 21, 2008 | 07:03 PM
In your case with the cv carb its called the "fuel/air" screw since the adjuster is closer to the front of the carb than say the 400,300,250 2-stroke carbs with the adjuster being closer to the rear of the carb and have "air/fuel"adjusters! Not trying to be a smart a**,but adjustment is more sensitive on your carb than the others! Plus if still has plug over adjuster, must carefully drill small hole,use a screw to pop out plug.Base setting should be between 2 to 3 turns outs. How I adjust one,especially if have one that has performance exhausts,etc,is to start at 2 turns at idle and turn out until starts to drop rpms,counting turns,and then in until rpm change,Then set midway between both points. BUT if just rebuilding,etc 2 1/2 turns out from lightly seated (closed) position should be ok. If boggy on accelerating,then try a little more out. Maybe I'm getting a little too technical,but depends on your situation. Plus this adjuster on either type carb affects basically just idle and slow jet response. Good luck
Old Dec 21, 2008 | 07:34 PM
1130all's Avatar
thanks for the help.i just put the 2 backwards when i typed.never to technical for me i work on a lot of atvs .
Jmuddin284
Jan 19, 2026 07:16 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
