remove air box lid
Old Dec 22, 2008 | 06:33 PM
hellya5029's Avatar
Default remove air box lid
someone told me i should remove the aribox lid on my moto4. what would it do and is it harmful
Old Dec 22, 2008 | 08:58 PM
hellya5029's Avatar
please. any advice would help
Old Dec 22, 2008 | 09:42 PM
raptor#420's Avatar
depends.. some info would help... what upgrades do you have (if any). What kind of filter? do you have a pre-filter? are you going to be riding water at all?
Old Dec 23, 2008 | 12:26 PM
hellya5029's Avatar
its all stock. there is a new airfilter in it. i ride in the snow but no water. if i was going to ride in the water i would put the lid back on.thanks
Old Dec 23, 2008 | 08:47 PM
raptor#420's Avatar
well if its stock there is not really a point.. i put a k&n filter with the lid on and it ran too hot..so i had to rejet and now it is running really bad.. so I would be careful about taking the lid off with a stock atv.. I'm fairly new to the whole "mods" thing because I just got my quad this last summer so some people might tell you otherwise.. but I would say get a new air filter a jet kit and some after market exhaust before taking off/drilling the air box lid..
Old Dec 23, 2008 | 08:48 PM
raptor#420's Avatar
oh and it would just let more air in to your carb.. if you do however do it make sure you have a pre filter [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Dec 31, 2008 | 08:27 AM
hotblooded's Avatar
I can only add that my bro had a Suzi Z250 and that thing would not run at all with the lid off. It had to be re jetted to get it to run
Old Dec 31, 2008 | 10:28 AM
ss97's Avatar
Lets Ride!
More air in means you will need more fuel in.....so if you open the box you will need to rejet....... otherwise you will be running way too lean, which will cause you to run too hot, which will eventually burn a hole in the top of your piston.....
Old Dec 31, 2008 | 03:48 PM
Hebs's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ss97
More air in means you will need more fuel in.....so if you open the box you will need to rejet....... otherwise you will be running way too lean, which will cause you to run too hot, which will eventually burn a hole in the top of your piston.....</end quote></div>
Like he said...
If you take the lid off... you need to rejet. You will gain a little power. You can probably get the jets you need for about 12 bucks...
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
