Prairie 360 4WD actuator
Old Dec 23, 2008 | 12:11 PM
dougie334455's Avatar
Default Prairie 360 4WD actuator
Just got a 360 Prairie 4x4, 2006 model. Runs great. One problem, the 4WD switch does not work. You hit the switch and nothing happens. Actuator does not work on the chunk and the 4WD light does come on either. Is there a fuse or something I should be looking for. Hoping someone else may have run across this in the past and can give me some guidance. Thanks
Old Dec 25, 2008 | 03:34 AM
Hayashi's Avatar
Primarily 5 possibilities:
1. 10-amp fuse for the Controller
2. Controller itself.
3. 4WD actuator
4. 2/4WD rocker switch
5. wire harness connection
If you want to get the job done right, get the manual, at least the electric diagram.
Njrider1230
Jul 29, 2023 05:16 AM
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
PrairieDog126
Sep 12, 2015 05:23 PM
