08 rims on a 02 Sporstsman?
My '97 and '01 had the same bolt pattern front and rear. I know it was the same because I swapped wheels front to back on the '97 to see how goofy it looked. I thought all Sportsmans were the same pattern front and rear, except the chain-drive rears.
Not sure then, some of the older models are hub centric on the wheels and the newer model wheels will not fit over the centering tabs on the hubs.
For example: 09 sportsman wheels will not fit an 09 Razor because the Razor is hub centric, the bolt pattern is the same. The offset is different between the SP and Razor also.
<div class="FTQUOTE"><begin quote>Originally posted by: plumbob
The part# for the hubs on a sportsman are the same as the rzr.</end quote></div>
Well they won't fit. Just tried it today.
