stripped drain plug hole
Old Dec 25, 2008 | 12:12 AM
x-runner kid's Avatar
Default stripped drain plug hole
I own a 2007 ds650x and some how my drain plug hole got stripped out how can i fix this any help is greatly appriciated
Old Dec 25, 2008 | 12:39 AM
cherokee99's Avatar
welcome to the forum! research this topic, ther have been alot of people with this problem. you can use a heli-coil if you are careful. dose your engine have a seperait cut out for a drain plug assembly? or is it simply molded to a case half?
if you are careful, flip you atv over and look threw the drain plug hole and see if there is anything you might dammage if you go too far into the case. if not go to the hardware store and buy a helicoil slightly larger than the current plug size. and a new bolt to be your plug
Old Dec 25, 2008 | 12:45 AM
I tried to research it but could not find anything the hole is molded into the case. and kinda a noob question but what is a heli coil. and the only thing i can see is a screen inside the hole and thats it.
Old Dec 25, 2008 | 12:50 AM
cherokee99's Avatar
ok, you dont wana hit the screen. a helicoil is basically going to rethread your draing hole, allowing you to use a larger size bolt. just find a guy at the hardware store and tell him what you need
Old Dec 25, 2008 | 01:34 AM
ok cool I will defenitaly have to try that thanks alot
Old Dec 25, 2008 | 10:52 AM
upnort's Avatar
Couple other possibilities. Can retap to the next larger size (metric or SAE) also & get a new plug. Or they make self tapping oversized plugs.
It would be nice if they made the plug softer than the hole threads so could just replace plug.
Old Dec 25, 2008 | 04:11 PM
NickDS650's Avatar
w/e you do, dont go a cheap route, i did this and just tryed to get a plug "to stay in there" or be "tight enough", cost me my engine. The drain plug stripped back out from not being sturdy enough, was a the race track makin a few laps, hittin the jumps dropped it out, i lost my oil, she stalled out and sounded horrible, got 'er home and found out i ruined my crank, pumps, piston, MY MOTOR! If you dont feel capable, have a mech put in that heli coil, the $50 is better to spend than $1500 [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 25, 2008 | 08:54 PM
cherokee99's Avatar
thanks for saying that nickds650! you can overstress that enough, if you dont feel confident have a mechanic do the heli-coil!
Old Dec 25, 2008 | 09:10 PM
ok thanks guys I think I am going to try and get a plug that is larger that is a self tapping plug just have to wait till places open tomorrow I will let you guys know how it turns out thanks again
Old Dec 26, 2008 | 01:57 PM
BigJon's Avatar
I took it to my local can-am dealer and they put in a new brass insert with a new plug. It was cheap - I had the oil changed and something else done it and it was $100.
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 19, 2015 10:13 AM
Coryco
Jul 6, 2015 07:30 PM
Shifts
Jul 3, 2015 07:59 AM
