PLOW PINS
Old Dec 25, 2008 | 11:10 AM
HARLEY_OWNER's Avatar
Default PLOW PINS
what do you guys use on your tubing to the mount... right nnow i just have some bolts but the nuts keep falling off because i cant tighten them.. i have a moose plow... im pretty sure the diameter is the same as others but i would like to know where you guys buy your pins or what you use to make it quiker and not loose stuff while your plowinng
Old Dec 25, 2008 | 11:44 AM
JCDEYO25's Avatar
Default PLOW PINS
I use a pin which looks similar to this......The link posted is just fro a pic not the size...
http://www.amazon.com/dp/B000O...76076-20&linkCode=asn
John
Old Dec 25, 2008 | 10:47 PM
user493's Avatar
Moto Psycho
Default PLOW PINS
When I had the kind of plow that needed them I used hitch pins that have a wire clip to hold them in. That's what came with the plow. I still have a few lying around but I don't know what size you're supposed to have for your plow. http://www.wilsonmfgco.com/hitchpins/wirelockpins.htm
Old Dec 26, 2008 | 03:53 AM
Dearlh's Avatar
Default PLOW PINS
[img]i/expressions/face-icon-small-happy.gif[/img]I use a similar pin as Jumbofrank only mine are square shaped wire clips. Here at my local hardware junkstore they call them "pto pins" $1.29 ea. Also I always have a couple spare nearby just in case. I also use them to secure my ramp under my trailer bed when I don't need to padlock it . Good Luck.
Old Dec 26, 2008 | 05:59 AM
sheepdogMSP8117's Avatar
Default PLOW PINS
I've never had a Moose pin break on me so that is all I've ever used.
Old Dec 26, 2008 | 10:21 AM
Default PLOW PINS
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
When I had the kind of plow that needed them I used hitch pins that have a wire clip to hold them in. That's what came with the plow. I still have a few lying around but I don't know what size you're supposed to have for your plow. http://www.wilsonmfgco.com/hitchpins/wirelockpins.htm</end quote></div>
thats the kinda pin i wanna find.. where can i pick them up.. i think they are 3/8's... dont quote me on it tho... but i remember someone sayin them numbers lol....
Old Dec 26, 2008 | 02:23 PM
Dearlh's Avatar
Default PLOW PINS
[img]i/expressions/face-icon-small-cool.gif[/img]Any fleet/farm supply store should carry those type pins. Do you have a Tractor Supply Store in your area? Good Luck!!
Old Dec 26, 2008 | 09:23 PM
Default PLOW PINS
i was at fleet farm today and forgot to look for themm.. .i'll check it out next time im there.. thanks boys
Old Dec 26, 2008 | 10:10 PM
user493's Avatar
Moto Psycho
Default PLOW PINS
They have hitch pins at Lowes and Home Depot, and any decent hardware store too. My plow had the pins with square wire loops to fit around the push tube. The Polaris Multi-Mount winch and bumper I had used smaller pins with round loops. Skinnier pins are good to latch a trailer coupler if you don't have a lock on it. Just make sure you get the right diameter and length. Probably 3/8" x 2-1/2 or 3 inch for the plow.
shimanok2
Jan 29, 2016 07:37 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
tysonbully
Sep 28, 2015 02:30 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
