1999 Polaris Xplorer Starter Drags
Old Dec 25, 2008 | 06:39 PM
civicminded's Avatar
Default 1999 Polaris Xplorer Starter Drags
I just bought a 99 polaris xplorer 300 4x4. It has 2000 miles on it and 300 hours on it. When you go to start it it starts ok but when your release the starter it "drags" it sounds like the starter gear is not retracting and still spinning the starter. It sounds awful. It will stop immediately when I rev the motor a bit and then its ok. If I do not rev the motor it will drag non stop. I have a friend with a 92 polaris ??? and his does something similar but its not as bad. He said its done it for a long time, What can I do to fix this? I am afraid it will tear something up.
Old Dec 25, 2008 | 11:14 PM
Common problem on ALL Polaris machines! You can try to grease starter bendix and try,but if as bad as you say probably best to replace. If its the original starter drive then its lasted a good while! YES it can do damage to stator and pickup coil if comes apart,cheaper to replace than a stator After market ones for less than $100 versus about $160 for OEM. Good luck
Old Dec 27, 2008 | 01:51 AM
Thanks, I may try to clean it up we will see.
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
cornermike
Jul 8, 2015 11:44 PM
tweeder
Jul 5, 2015 01:57 PM
