1994 Kawasaki Mojave 250 Only Starts By Compression Staring It
Old Dec 26, 2008 | 01:05 PM
Mojaveman48's Avatar
Default 1994 Kawasaki Mojave 250 Only Starts By Compression Staring It
My 94 mojave will not kick start i can kick it till i turn blue in the face and it will not start but if i have my buddy pull me in 1ST and i hlod the clutch in untill we start to go like 8mph and i let go of the clutch and the tires make like a half of a revaltion it will fire right up no problem also it will only run with choke or it will stall and it needs to have the idle turned up to or it will stall its staring to **** me off because i cant shut the thing off please help any ideas
Old Dec 28, 2008 | 12:10 AM
jeffeosso's Avatar
check the compression... bet it under 120???!!?!?!
runs fine, after you push start it, but if you let it die, it won't start again unless you pull it, right?
did it smoke AT ALL?
might need valves, might need rings, might need a head gasket
bulldog454545
Jan 27, 2001 10:12 PM
primey
Mar 5, 2000 01:36 AM
dunc_n
Aug 26, 1999 09:32 PM
RidE
Aug 6, 1999 02:34 PM
