neutral safety switch
Old Dec 26, 2008 | 07:06 PM
mybigdeer158's Avatar
Default neutral safety switch
i have a 1986 honda trx 250 fourtrax and i am tring to bypass the neutral safety switch.does anyone know how i can do this? it would be greatly appreciated
Old Dec 27, 2008 | 06:14 AM
HondaMechanic's Avatar
To bypass the neutral you have to ground it , but the neutral light will stay on all the time .. What is wrong with the neutral switch ..?.. If it is bad just swap it for the reverse switch ..
Old Dec 27, 2008 | 10:09 AM
ok heres the deal i started to only get fire some of the timeand now there is none,i changed the coil,cdi box,and the regulator,still nothing,i thought maybe the pulse generator.but then a guy told me that those switches went bad a lot on those bikes.but do not even know were it would be located.thanks for the help
Old Dec 27, 2008 | 01:07 PM
wezersworld's Avatar
i have an 01 rancher that the same thing went wrong on. it seems that it is a common problem. my quick fix: i looked at the wiring diagram and traced the wire. i put a safty pin through the wire, attached another wire from that to a toggle switch, and from there to the frame. now when i want to start my bike i close the switch the neutral light comes on, i start the bike then flip the switch and ride on
Njrider1230
Jul 29, 2023 05:16 AM
hueby
Aug 28, 2015 07:26 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
ScopeZ_
Jul 28, 2015 01:44 AM
