AWD switch
Old Dec 26, 2008 | 07:37 PM
Pstroke7_3's Avatar
Default AWD switch
Hello everyone I have what I think is a simple problem but I am stuck without some very pertinent info. I want to Bypass my shifter activated switch for my AWD on my 95 Xplorer. I'm going to try and put in a regular toggle switch on the headlight pod to activate the AWD. I only need to know the function of the four wires coming out if the shifter assembly. I don't have a wiring scematic and can probably figure this out myself given a day or so. I am curious if anyone else out there has done this before and what kind of luck they've had with it. I figure if it's wired right, I will be able to switch from 4wd to 2wd and back with a regular toggle and not have to buy another $100 Polaris part that is a micro switch and 4 24 in wires worth about $12.50. Thanks in advance for any help/input.
Old Dec 28, 2008 | 04:27 AM
2006copperspecial's Avatar
Default AWD switch
Hi
According to my cheap Haynes manual,the wires are as follows.
red and white - power in (12 volts)
green and white - neutral indicator light
purple - reverse indicator light and over-ride switch
gray and white - awd switch and over-ride switch
I hope this info helps.
A. J.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 28, 2008 | 05:42 AM
fatnbald's Avatar
Default AWD switch
For what its worth, my AWD switch was working very poorly. I took it apart and cleaned it, now it works mint. Its pretty simple inside, so unless something is physically broke I think your ok.
Old Dec 28, 2008 | 08:05 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default AWD switch
i would try cleaning it first and by pass it if need be. imo.
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
toonces
Sep 5, 2015 01:14 PM
