1994 Kawasaki Mojave 250 Only Runs With Choke
Old Dec 26, 2008 | 11:29 PM
Mojaveman48's Avatar
Default 1994 Kawasaki Mojave 250 Only Runs With Choke
Only runs with choke on or else it will stall also he idle needs to be turned up to any ideas
Old Dec 27, 2008 | 09:58 AM
Kerbbirds's Avatar
Carb needs cleaned, pilot jet plugged.
Old Dec 27, 2008 | 01:21 PM
which one is that im not fermilur with kawasaki carbs
Old Dec 28, 2008 | 12:05 AM
jeffeosso's Avatar
its the largest jet... get a $25 rebuild kit, and replace all the parts, if you need the part..
take off float, needl valve, pull great big jet, clean out gunk, put in an inline filter
Old Dec 28, 2008 | 08:15 PM
95wolv's Avatar
jeffeosso, the pilot is not the bit jet, that is the main jet, the pilot is usually found right in front of the main, inside a little tube, you need a small screwdriver to remove it. the port in it is so small, you can barely see light through it, very easy to gum up and plug, make sure it is squeaky clean by blasting carb spray through it and blowin it out . Without the pilot jet, it will not idle, or idle very badly.
Old Dec 28, 2008 | 08:43 PM
jeffeosso's Avatar
okay. .then main jet is where they get junked up badly.. its basically main fuel line to there.. then into the carb, then up the pilot, main, and fuel mixture...
Old Dec 28, 2008 | 11:49 PM
ok is this why i can kick the engine till im blue in the face and it will not fire if i compression start it it will run but very shity
Old Dec 29, 2008 | 12:14 AM
95wolv's Avatar
when you pull start it, the motor turns over a lot faster,and longer than a kick,so that's why it will start, but with a gummed up idle circiuit, it will not idle very well. If you don't feel comfortable taking the carb apart, take it off the quad, and to a shop for a good cleaning, or find a buddy with some tools and experience. It isn't that hard to take the bowl off, clean out passages with a can of cleaner, remove the jets and clean all the little holes and reassemble. If nothing else, find a good Haines or other manual for instructions.
Old Dec 29, 2008 | 12:49 AM
also it boggs out sometimes while im driving at a high rev and than it comes back if i back off the throttle on that to any ideas
Old Dec 29, 2008 | 01:24 AM
95wolv's Avatar
Sounds like junk in the bowl causing fuel to be choked off, your best bet is a good cleaning out of the carb, let us know how it goes after that.
