X2 Bed Protection?
Old Dec 28, 2008 | 01:17 PM
Chadly1980's Avatar
Default X2 Bed Protection?
Hey Guys,
I have been here a little bit reading up before I get to purchase a Polaris X2 this coming fall after a wedding, buying a house, etc...anyway...
I was wondering if anyone has put some sort of liner on their bed for the X2? Such as LineX? Is it worth doing?
Thanks for any thoughts you can share.
Old Dec 28, 2008 | 01:52 PM
RticKwad's Avatar
Runs Stealth!
Polaris also makes a rubber mat for the bed too.
P.S. Don't buy that spray rubber material from the hardware store, I found it to be useless!
Regards,
R'
Old Dec 28, 2008 | 04:08 PM
NoJoke's Avatar
Howdy Chadly1980......try this link. I have this bed protector and it's very heavy duty.
http://www.purepolaris.com/Det...849(PolarisPGACatalog)
Old Dec 28, 2008 | 06:25 PM
Chadly1980's Avatar
With that bedliner, though, you would have to take it out when you go 2-up?
If there were a spray-in bedliner, it would prevent things from sliding around, take more abuse, etc. Do any owners out there have an X2 and think they wouldn't mind having it sprayed with rhino tuff, lineX or whatever? I wonder what the cost would be on it.
Old Dec 28, 2008 | 07:51 PM
cscotter's Avatar
I also wondered if I could do a spray in on my x2. I figured it probably wouldnt work because of the moving parts on the flip up panel. If you wanted to spray it right, you would have to spray around the underside a bit on the overlapping lip of the flip up panel. Seems like it would interfere with the operation of the setup, wouldnt close properly. I thought about taking it to my local line x dealer to get their opinion but never did because I didnt think they would reccomend it.
So I just bought the polaris bed mat, got it a couple days ago. Pretty heavy duty. The rubber is about 1/2 inch thick. It is a bit of a pain having to remove it for 2 up riding. Oh well.
Old Dec 29, 2008 | 10:12 AM
*5 J's*'s Avatar
As NoJoke says the Polaris bed protector is VERY heavy duty - but you do have to remove it to go two-up.
I bought one - but never had the need to use it. I suppose if we were building a bridge on a trail and I need to haul rocks I could use it.
<div class="FTQUOTE"><begin quote>Originally posted by: Chadly1980
If there were a spray-in bedliner, it would prevent things from sliding around, take more abuse, etc. Do any owners out there have an X2 and think they wouldn't mind having it sprayed with rhino tuff, lineX or whatever? I wonder what the cost would be on it.</end quote></div>
Old Dec 29, 2008 | 04:23 PM
I also have the bed protector and can ditto all the comments above. Very heavy duty, need to take out when 2-up, etc. You might consider Herculiner. It's like Rhino or LineX but you roll it on. You can get a gallon for about $85 or so. Not sure of the per quart price. I wouldn't spray in because of all the moving parts. If I were to do it, I'd tape off all screw heads and do the box and the lift up part seperately masking off the other part as you go. I put Herculiner on my old wooden boat seats 4 years ago and they are still like the day I did them.
Old Dec 29, 2008 | 04:29 PM
RyanJ's Avatar
I've used the spray-can bedliner on a variety of surfaces (sometimes even truck beds!) and it's always held up well. I think it would be a great choice for a low-buck way to add some protection and non-skid to the bed of your X2. Just do the prep work and mask everything off well to be sure no spray gets anywhere it shouldn't.
Elkaholic
Sep 6, 2015 02:44 PM
antiguogrumete
Sep 5, 2015 03:41 AM
Captjay
Jul 23, 2015 12:33 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
