polaris problems
Old Dec 28, 2008 | 07:57 PM
cdogkiller's Avatar
Default polaris problems
yes i have a polaris 325 magnum 4 stroke engine. sometimes the wheeler will run fine then it will die on me and it run like it dies out like it want hit. then all of a sudden it will run and it might run 10 minutes then die and ill have to wait alittle while for it will start back and then it may not run well. anyone have any ideas wat i can do, i have cleaned my carb out already and i dont no wat else todo. just wandering if anyone else has had a problem like that. tks for reading
Old Dec 29, 2008 | 04:11 PM
Does your quad have a Stator? I had an Xplorer 250 that had similar problems and it turned out to be the stator. Anyone???
Old Dec 29, 2008 | 07:35 PM
ftwflh's Avatar
Check the gas tank vent line
Old Dec 30, 2008 | 10:24 AM
cdogkiller's Avatar
hey tks for the information man i hate to sound ignorant but i dont even know wat a stator is. but i will found out and see if that is the problem tks for your help. have a blessed day and a blessed week tks again
Old Dec 30, 2008 | 10:56 AM
TLC's Avatar
TLC
Check the cheap stuff first,tank vent like mentioned and ignition coil. Like the stator windings a coil can heat up and quit as the windings expand,than as the cool and contract they make contact once again.
Old Dec 30, 2008 | 10:36 PM
cdogkiller's Avatar
thanks tlc i appreciate it
green giant
Jul 13, 2017 12:07 PM
DJS
Jun 28, 2015 11:34 AM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
hoopduerr
Jun 1, 2015 08:22 PM
