02 Sportsman Stalling when plowing
Old Dec 29, 2008 | 12:50 PM
tripleplaytours's Avatar
Default 02 Sportsman Stalling when plowing
Hi, my sportsman 400 runs fine spring summer an fall, but the winter is a killer, if it doesn't warm up for like 25 minutes it stalls whenever I go into reverse, hi/lo forward seems to be Ok I think (I can't really remember) I adjusted the etc to 1/8" and I bumped up the idle so when I change gears the bike actually jumps a bit (too much idle maybe) is it a carb issue, and I changed the plug, and load tested the battery (fine) it seems temperature related, also I broke off the hi/reverse shift linkage bar b/c it was really hard to shift (probably related to the hi idle rpm??)
Old Dec 29, 2008 | 02:23 PM
Speeddrive1's Avatar
Turn the idle mixture screw out 1/4 to 1/2 turn and that should help.
Old Dec 30, 2008 | 01:08 AM
I'll try it, but first how can I identify which one it is?
Will I have to turn it back in after the winter?
Thanks so much
Old Dec 30, 2008 | 07:58 AM
http://pi54.com/corp/manuals/Parts/9917537.pdf
Hope this works as a link, looks like part 26 is the idle mixture screw. It might have a
brass plug over it that you have to drill a small hole in and use a sheet metal screw
to pull it out.
Old Dec 30, 2008 | 08:39 AM
Kerbbirds's Avatar
ditto on the air fuel screw, should be 2 to 2.5 turns out, I have seen them completely shut from the factory, its on the bottom of the carb and probably does have a brass plug over it.
Old Dec 30, 2008 | 09:28 AM
MrMarty51's Avatar
Thank You for the Parts Manual and the info. on the carb.
My 400 Sport does`nt like to idle too good in colder weather too but I now know where to go to get it adjusted.
Whenever I get a new or new to Me machine I usually get the parts and repair manual too.
Is there someplace to get the repair manual for free like this parts manual?
OOOPPPSSS I just looked at the thread and this is for the 02,Are they the same as the 05?
Old Dec 30, 2008 | 10:25 AM
http://pi54.com/corp/manuals/Parts/9919413.pdf
here is for 05
you can get this on polaris website. Just set up an account and then you can download any parts manual.
Old Dec 30, 2008 | 11:39 AM
MrMarty51's Avatar
Thank You very Much.
I tried to change the parts to repair but it came up with page could not be found.LOL
I will order the repair manual.
I am surprised that these engines have rockers with adjusters instead of shims.That will make valve adjustments much easier.Sorry,did`nt mean to hijack this thread.[img]i/expressions/face-icon-small-happy.gif[/img]
readymixer169
Aug 21, 2015 10:05 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
fire1998
Aug 6, 2015 02:46 AM
Gtsordo
Jul 22, 2015 01:27 PM
Gtsordo
Jul 13, 2015 10:38 PM
