flywheel ceased
Old Dec 30, 2008 | 07:02 PM
snupills's Avatar
Default flywheel ceased
ok....i have a 99 polaris sport 400...the flywheel has ceased up...and this caused the starter to be mangled. now....fly wheel will not turn at at...any suggestions>(how it happen) reverse has never worked....tryed puttin it in reverse last time rode and hats when it would not start up at all after that.
Old Dec 30, 2008 | 07:26 PM
eggenz7's Avatar
do you mean the motor will not turn over at all or you can not get the flywheel off the crank? the reverse could just me a misalignment. try uplugging the black wire on the rev limiter box.
Old Dec 30, 2008 | 07:31 PM
snupills's Avatar
nothing will turn over....if you try to start it would make a single attempmt to crank..and when this happen it mangled the starter.. we took the cover off, and tryed to turn the flywheel manually...will not budge, and had to remove the starter caus it was destroyed
Old Dec 30, 2008 | 07:33 PM
eggenz7's Avatar
sounds like you have a froze piston. time to take the jug off the motor. if you can not get the crank to roll then you need to tear the motor all the way down and replace crank bearings.
dont see how the reverse gear would cause any of this because its two seperate mechanical entities.
Old Dec 30, 2008 | 07:34 PM
TLC's Avatar
TLC
The flywheel is connected to the crank shaft ,the crank shaft is conected to the piston rod the piston rod is connected to the piston. If motor is seized,so is the flywheel.
Old Dec 30, 2008 | 09:57 PM
1130all's Avatar
i would take the flywheel off and check and make sure the magonets did not come off and lock the crank.it happened to a trail blazer i had
Old Dec 31, 2008 | 12:48 AM
user493's Avatar
Moto Psycho
I think your engine is deceased. Time to rebuild it.
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
