flywheel ceased
flywheel ceased
ok....i have a 99 polaris sport 400...the flywheel has ceased up...and this caused the starter to be mangled. now....fly wheel will not turn at at...any suggestions>(how it happen) reverse has never worked....tryed puttin it in reverse last time rode and hats when it would not start up at all after that.
flywheel ceased
sounds like you have a froze piston. time to take the jug off the motor. if you can not get the crank to roll then you need to tear the motor all the way down and replace crank bearings.
dont see how the reverse gear would cause any of this because its two seperate mechanical entities.
chingchangchong
08-07-2022 11:36 AM
Scooter's Shop
23
10-22-2015 07:04 PM
