Transmission/Shift Lever Problems..
Old Dec 31, 2008 | 05:07 PM
Caesar09's Avatar
Default Transmission/Shift Lever Problems..
Hi guys. I'm new to this site, and I hope someone can help me out.
I have a '97 Kawasaki KVF400 Prairie 4WD ATV, and a couple days ago, after riding, my Gear Shift Lever, which is usually "tight" against the body when in Neutral, all of a sudden became very loose and just hangs there. It appears that there is a "plate" underneath it that it should be locked into, however, it isn't. I can still engage the Low/High/Reverse gears, however, the plate only "follows" the Lever in the High gear. I hadn't used it in a few days until today when after maybe 25mins of riding, while in High gear, I lost everything, like it went into Neutral, and I heard funny noises, like it was trying to dis-engage itself. I came to a stop as soon as I heard it, then it re-engaged itself (without me moving the Gear Shift Lever). I parked it ASAP and came online and googled my problem, and found this site after some searching. Hopefully someone can help me out. Thanks for your time.
Old Jan 1, 2009 | 05:32 AM
smitty800's Avatar
i would take it to the shop and have them tell you what the problem is and if you can fix it yourself. that would be your best bet
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
