CV joint removal
Old Feb 6, 2001 | 06:05 PM
scramblerjer's Avatar
i somehow got a rip in my cv boot. took most everything apart but not sure how the cv joint comes off the shaft. HELP PLEASE!!!
Old Feb 6, 2001 | 09:31 PM
please help!!
Old Feb 6, 2001 | 11:16 PM
Farmr123's Avatar
The shaft is held in the CV joint by a spring-clip. Usually a sharp tug is all that is needed to seperate them. You will likely have to remove the ball joint at the bottom of the strut off the a-arm to get enough clearance to remove the shaft from the CV joint. When you put it all together, be sure that the shaft 'clicks' back into the CV joint.
Old Feb 7, 2001 | 12:51 PM
Scott's Avatar
Definately a sharp tug. Actually it took a block of wood and a hammer to get mine off. (The wood acts as the strike surface to protect the CV joint from damage). Doesn't that suck, all that work to replace a boot? Such is life...ignore it and see what happens!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
89Lt250r
Sep 7, 2015 07:53 PM
