Replacement Stator 500 Sportsman
Old Jan 4, 2009 | 04:17 PM
Mud Runner 's Avatar
Default Replacement Stator 500 Sportsman
The Stator in my 500 sportsman is shot. I found RM Stator on Ebay about 1/3 the cost of OEM. Here is their web site http://www.rmstator.com/en/index.php , although the ebay pricing is better.
My question is has any one purchased anythign from this company? If so have you been satisified? I'm trying to save a few bucks, but if I have to replace it with OEM at a later date it ends up coting me more.
Thanks
Old Jan 4, 2009 | 04:20 PM
ftwflh's Avatar
You take a chance with all after market electrics.But I have found that most are decent but dont last as long as OEM
Old Jan 4, 2009 | 05:29 PM
alphadriven's Avatar
I would first make 100% sure your stator is bad and not maybe just a trigger coil. I found mine to be just a broken wire not making consistent connection. see my thread
http://forums.atvconnection.co...51530&highlight_key=y
otherwise if you can find an oem replacement on ebay for a decent price I would buy that. If no good deals on ebay then use rm stator. I purchased an oem stator new off ebay just as a spare pretty cheap.
Old Jan 4, 2009 | 06:29 PM
I have the Stator out. The problem I have is on the red and red/black wire going to the stator I should be reading 44O Ohms. I have an open. Does this mean that the trigger coil is out of it? I did notice one of the windings on the stator near the bottom appears burnt. I thougt these were for the charging circuit? Can the trigger coil be replaced on the stator assembly?
Thansk
Old Jan 4, 2009 | 06:35 PM
94harley's Avatar
Your stator is shot then. The pulser/trigger is the black box that is on the outside of the flywheel.
Old Jan 4, 2009 | 09:17 PM
dave.570's Avatar
i have had rmstator repair my sled stator, and was better than stock, with one year warranty.
Old Jan 4, 2009 | 09:27 PM
Thanks for the input. I think i will order off of Ebay from RM Stator.
Old Jan 4, 2009 | 09:56 PM
dave.570's Avatar
that is what i did. they do have a pretty fast turn around also. if it is for a stator repair you will have to ship them the one from your quad.
Jmuddin284
Jan 19, 2026 07:16 AM
jettman
Jul 6, 2015 12:16 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
