help with kawasaki mojave
Old Jan 11, 2009 | 02:35 PM
mojavescott's Avatar
Default help with kawasaki mojave
i have a 2003 kawasaki mojave 250 it won't start but a guy told me to check the valve timings if you know what else to do beside the spark plug and clean the carb please help me fix it
Old Jan 12, 2009 | 08:29 AM
jeffeosso's Avatar
check spark
change fuel
check compression
check timing
compression, fuel, fire, and timing are the basics, right? if you have all 4, its adjustments or fuel.
Old Jan 14, 2009 | 01:34 PM
if the timing is off it wont start? we replaced the plug and clkeaned the carb.
Old Jan 14, 2009 | 03:48 PM
Guest
Guest
Posts: n/a
it could be timing if its out that bad..these will run if their advanced or retarded by a tooth or so on the cams, but wnt run if cams were timed with the piston not at top dead center...im not sure how much clearance there is with these stock but i know with performance cams you will smash valves if the cams are out of time...did it run before?
Old Jan 16, 2009 | 12:38 PM
no i did not i traded my dirtbike for it
Old Jan 17, 2009 | 06:48 PM
AMAhillclimber's Avatar
They have had some problems with stators. Check valve adjustment and do a compression check.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
