Idles fine but then a stumble
Old Jan 13, 2009 | 05:43 PM
jpn800's Avatar
Default Idles fine but then a stumble
I just picked up a 05 Sportsman 500ho, 124 miles it has been sitting for a while so I cleaned the carb (pilot jet was gummed up) Now it will start up fine and it idles great. when I give it gas it dies out, Almost sounds like its starving for fuel I play with the throttle and keep "pumping" back and forth and it will clear up after a min or so. All is well after that. It did the same thing after two cold starts. I also checked the throttle cable adjustment but I'm unsure of what it should really be set at, I have so there is about an 1/8" space between the contact on top of the thumb throttle. Please advise on what to check. Thanks
Old Jan 13, 2009 | 05:47 PM
Still sounds like carb problem,plus check tank vent line,OLD GAS,did you flush tank also,new plug air filter,etc? Could be any of these
Old Jan 13, 2009 | 06:55 PM
jpn800's Avatar
I did put in new gas, I didn't flush the tank. If it were the plug or filter would the problem go away after a min or so? I also looked at the vent tube, Blew into it and it seemd ok. What else could be wrong in the carb? Thanks for the speedy reply
Old Jan 13, 2009 | 06:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe change the fuel filter as well and did you completely clean all the fuel passages as well as the jets? this would be a cause. make sure filt is clean(most likely is).
Old Jan 13, 2009 | 07:04 PM
jpn800's Avatar
Yes all the jets were removed and cleaned. All Fuel passages were sprayed with carb cleaner to make sure they were unobstructed. Then everything was blown with compressed air. The fuel filter is original and might be one of the problems. I'll order a filter and a new plug just to be sure. Thanks
Old Jan 13, 2009 | 07:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure the float is set level as well just to be safe.
Old Jan 13, 2009 | 07:14 PM
jpn800's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
make sure the float is set level as well just to be safe.</end quote></div>
How do i do that?
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
Jul 30, 2015 09:39 AM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
