What Winch MOUNT Should I Use?
Old Jan 14, 2009 | 03:19 PM
boomsoon's Avatar
Default What Winch MOUNT Should I Use?
Decided to go with a Warn RT30 on my '07 Sportsman 800.
Which mount should I use? Is there any drawbacks/advantages to the Warn?
Old Jan 14, 2009 | 03:35 PM
jchunn's Avatar
I don't know anything about the various winch mounts out there, but I can tell you a complaint I have with mine (I don't even know the brand). The rollers do not stick out far enough, so when I attach the hook to my Moose plow, the cable is pointing straight down, and rubs against the frame of the mount, causing wear on the cable and the bracket that connects the hook to the cable. Just something to be concious of... if the cable is straight down, does it touch anything? That would be what I would watch for.
Mine is an older setup. I would guess that the newer winches, mounts, and plows do not have that issue, but I just thought I'd share my experience. Bottom line, think about what things you might be using it for that might be unusual, and consider anything that could be a factor for that application.
Old Jan 14, 2009 | 04:11 PM
hobbles's Avatar
Afternoon boomsoon
go here and look under winch mounts>Polaris. You will get every darn thing you will need to do the job, even an instruction sheet.
Old Jan 14, 2009 | 04:36 PM
boomsoon's Avatar
Thanks hobbles!!
<div class="FTQUOTE"><begin quote>Originally posted by: hobbles
Afternoon boomsoon
go here and look under winch mounts&gt;Polaris. You will get every darn thing you will need to do the job, even an instruction sheet.</end quote></div>
Old Jan 14, 2009 | 04:41 PM
hobbles's Avatar
Old Jan 14, 2009 | 05:29 PM
700 sportsman's Avatar
KFI mount plates are very nice and have a nice price tag too
Old Jan 14, 2009 | 05:30 PM
OIown12's Avatar
These guys are top notch. Powder coating is great, everything is strong and it fits perfectly. Shipping is fast and mount is under $40.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
