Looking for advice
Old Jan 16, 2009 | 12:11 PM
Austin8214's Avatar
Default Looking for advice
I am looking for input on a purchase. I am currently considering buy either and Artic Cat 400 or Suzuki 400 I am looking for your input and pro's and cons of each unit. I am primarily going to be using the ATV for plowing my driveway in the winter and just general riding around in the summer.
Old Jan 16, 2009 | 07:53 PM
swampyjunior's Avatar
Either are good machine. The AC is more of a Utility ATV than the Suzuki would be. The Suzuki will be more of a soprt feel to it. Both will work for plowing.
If you plan to plow I would get rid of the stock tires (usually dunlop) and put on an agressive tread like a Mudlite , maxxis bighorn, Kenda bearclaw or someting similar. Also get a 60inch plow. Both of the machines you listed are about 50inches wide so by the time you angle a 54inch plow you are not clearing a swath wide enough for your tires. A 60inch plow is much better. Depending on how much wet snow you get you may even need to get a set of 4 tire chains.
SJ
Old Jan 17, 2009 | 08:17 AM
Austin8214's Avatar
Thanks for the reply. Are there any known mechanical deficiencies in either machine?
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
