Plow Adjustment springs?
Old Jan 19, 2009 | 11:03 AM
Titleist's Avatar
Default Plow Adjustment springs?
Hey guys I have an AC plow on my 04 500,..the springs seem loose n wobbley and when the plow is angled one side rides above the ground, I raised up the skids but it still sits ****-eyed.
Old Jan 19, 2009 | 06:31 PM
cupsz71's Avatar
Not sure if/how the spring tention affects how your plow sits. They're to provide a "buffer" to allow your plow to absorb sudden stoppage so you don't fly over the handlebars.
I've got the composite AC 60" plow & A-Frame on my TRV, and my plow springs are not cranked tight, and my lower skids are set at almost the same height as the plow edge.
Straight or turned either way, when I drop the plow down, it sit's level on the skids/ground.
I'm think'n you may have unfortuneately BENT something w/a hard impact recently. They can REALLY bend if you were cranked off at a sharp plow angle and came to a sudden harsh stop.
Check over your set-up and do some "eye-ball'n" measuring. You'll get your answer as to HOW/IF things are bent.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 19, 2009 | 07:29 PM
v2rider's Avatar
+1^ Something sounds tweeked
Old Jan 20, 2009 | 10:30 PM
swampyjunior's Avatar
Something sounds like its bent on the support arms OR a spring has come loose or broke.
SJ
Old Jan 21, 2009 | 12:39 PM
DUFF650V2's Avatar
I keep a sledge hammer in my soft bag when I plow 'cause the mounting brackets always bend every other big storm in NYS. Give them a couple of good hits eye them up and your all tightened up again GTG!
Old Jan 21, 2009 | 12:45 PM
DUFF650V2's Avatar
gonna replace them this year so that they don't snap on me from bending back and forth for three years.
readymixer169
Aug 21, 2015 10:05 AM
Stever6368
Aug 16, 2015 07:34 PM
dougn85
Aug 5, 2015 07:20 AM
Gtsordo
Jul 22, 2015 01:27 PM
Gtsordo
Jul 13, 2015 10:38 PM
