Have blink codes need HELP
Old Jan 23, 2009 | 06:11 AM
jerrymi's Avatar
Default Have blink codes need HELP
I have an o4 700 efi sportsman, i was working on the tail light and touched the hot wire to the frame, I have the following blink codes 41, 32 56. I do not know what code 32 is. My fuses are all good. When i go to start it, the speedo powers off and then comes back after a few seconds.
How do i clear the blink codes?
Once i clear the code it should start again? or is there more i need to do?
Old Jan 23, 2009 | 03:37 PM
jerrymi's Avatar
Any ideas
Old Jan 23, 2009 | 04:18 PM
summerjack's Avatar
have you disconnected the battery (both +/-), let it sit for several minutes and then reconnect?
Old Jan 23, 2009 | 05:14 PM
jerrymi's Avatar
Yes i did, the fuel pump still does not fire up. I used jump leads to make sure it is good it fires up that way. I donot see the code on the speedo any more
Old Jan 23, 2009 | 06:38 PM
700 sportsman's Avatar
I have the link to the 03 700 service manual, I will post back when I get home
Old Jan 23, 2009 | 09:11 PM
summerjack's Avatar
when did the fuel pump come into play?
speedbuff
13
Nov 11, 2020 10:16 AM
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
