25" tires on a Trail Boss (TB)
Old Jan 24, 2009 | 08:34 PM
RticKwad's Avatar
Runs Stealth!
Default 25" tires on a Trail Boss (TB)
All -
Just wondering how my SP450 stock 25" tires
(whole set) would do on my friends Trail Boss?
My thinking is when I upgrade my tires on the SP800
this year, I will then transition my 26" tires to my SP450
then I can wheel&deal (no pun) with my friend. I know the
TBs tires are smaller from looking at them but I don't know
the measurement. I am thinking he would get better tread
and an inch clearance possibly?
Any issues with needing clutch adjustments or spacers or
anything. From the looks, seems that it would be a good fit.
Thoughts?
Thx,
R'
Old Jan 24, 2009 | 09:01 PM
eggenz7's Avatar
Default 25
i would say it definatly would need a clutch kit. thats a big jump on tires sizes for a tb.
Old Jan 24, 2009 | 10:46 PM
RticKwad's Avatar
Runs Stealth!
Default 25
What are we talking eggenz7? What are the stock size on the TB?
Regards,
R'
Old Jan 24, 2009 | 10:55 PM
Raven95150's Avatar
Default 25
I suppose it depends on the year, but the newer ones are 23 front and 22 rear, same as the Scrambler/Trailblazer.
Old Jan 24, 2009 | 10:59 PM
RticKwad's Avatar
Runs Stealth!
Default 25
He has a 2005 TrailBoss and I have a 2006 SP450 (wifes, didn't sell, decided to keep it).
I thought it was something like 23" or 24". But would he really need a clutch kit or something
that aren't really big tires?
Thanks for the info.
R'
Old Jan 25, 2009 | 08:09 AM
eggenz7's Avatar
Default 25
didnt know they upped the sizes on them. if its only an inch or two and they arent heavy tires then it would probably be ok. if they are heavier tires it takes more force to get them going which would require a heavier primary spring.
Old Jan 25, 2009 | 06:58 PM
RticKwad's Avatar
Runs Stealth!
Default 25
You know I forgot my cousin has two Hawkeyes for his boys. I wonder if my SP450 25" 489s
would fit on their Hawkeyes, may be a better way to go. Not sure the stock tire size on them?
Same question, any wheel spacer kits needed or clutch mods?
Regards,
R'
Old Jan 26, 2009 | 12:13 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default 25
I had a 1997 Trail Boss 250 with 25" Bearclaws and had no problem at all. Had it 4 years with those tires and never a problem.
Old Jan 26, 2009 | 05:44 PM
ftwflh's Avatar
Default 25
To compensate for the bigger tires lighten up on the secondary spring tension
RickyMac
Mar 5, 2016 07:27 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
toonces
Jul 21, 2015 02:40 AM
Gnuters
Jul 19, 2015 10:03 AM
