no spark
Old Jan 26, 2009 | 11:53 AM
02popo's Avatar
Default no spark
I currently have no spark to the plugs. This happened at the exact time I tried to install a timing key. After the flywheel didn't just come right off like i was told it would i tried to "tap" the end of the puller to get it to release. Now i wonder if i could have damaged the pickup or ?? I checked to inputs to the coil with a test light while cranking and found no voltage. I do not have a service manual so i'm not sure what is supposed to be there. Can anyone help with some ideas on what to check??
THANKS TRAMENDOUSLY.
02popo's Avatar
Default no spark
Sorry, its an 02 700 sportsman.
Old Jan 26, 2009 | 12:55 PM
02popo's Avatar
Default no spark
This is the most technical polaris bunch i have found. I was hoping some of you guys had some ideas. Is there another site out there??
THANKS
Old Jan 26, 2009 | 03:07 PM
jchunn's Avatar
Default no spark
Patience, grasshopper... give it 24 hours and I'll bet you get some responses.
Old Jan 26, 2009 | 03:13 PM
02popo's Avatar
Default no spark
Thanks, just been racking my brain on this for about a week and just found you guys recently. Killing me to get this taken care of.
THANKS!
Old Jan 26, 2009 | 04:20 PM
eggenz7's Avatar
Default no spark
if the flywheel did not come straight off (which is very likely) then it could have hit the pickup coil causing the airgap to be off. have you tried cranking it with the pull rope? there have been a few success stories doing it that way. the starter can not spin the motor fast enough to get the pulse coil to activate but a hefty pull the rope will fire it up every time. .022 ~.028" is the gap setting. give me a second and ill post up the link to a manual to your machine.
well i cant find the link posted on here. id bet that somebody will post it this evening
Old Jan 26, 2009 | 07:38 PM
02popo's Avatar
Default no spark
I have never seen a pull rope on this bike.....??
And the flywheel finally came off. Let it set all day with a pull on it. tapped it a few times and bam, off it jumped at me.
Now i see what might be the problem. Apparently a bolt was in too far on the puller and when the flywheel turned it knocked one of the two wires off the stator( i thnk thats what that is behind the flywheel).
I thought that was just for charging the batt though. Is it part of the ignition?? Because all of this started with me trying to get the flywheel off. Hoping i can resoilder the wire back on and be good to go.
THANKS
PS. i would love a link to a service manual.
Old Jan 26, 2009 | 08:32 PM
eggenz7's Avatar
Default no spark
Link for manual
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
