85 Big red Carb Problem
I changed out the carb on my 85 big red.When i started it up, it immediatley went to about 2000 rpms.I tried adusting pilot and idle screw nothing seems to affect it.Could the choke be stuck open?
the throttle should have a little play. IF the cable has no play it will cause it to do that. If not the cable, reset the pilot screw to 2 1/4 turns out from being seated. Loosen idel screw all the way. Start vehicle, warm up adjust throttle, than pilot to stall, than back 1 turn on the pilot.
