85 Big red Carb Problem
Old Jan 26, 2009 | 03:32 PM
kpg's Avatar
kpg
Default 85 Big red Carb Problem
I changed out the carb on my 85 big red.When i started it up, it immediatley went to about 2000 rpms.I tried adusting pilot and idle screw nothing seems to affect it.Could the choke be stuck open?
Old Jan 26, 2009 | 03:58 PM
nickdodd25's Avatar
Try the trottle cable it most likely will have a adjuster on one end for the idle. It may be where the cable and the carb meet.
Old Jan 27, 2009 | 07:31 AM
kpg's Avatar
kpg
I tried adjusting that and everything else i could.I checked out the choke and it looks good.I did fail to mention that the carb on there is off of a 85 trx250.
Old Jan 27, 2009 | 02:21 PM
honda185s's Avatar
Does it backfire at all when you hit the gas? Pull the plug and check what color it is.
Old Jan 29, 2009 | 11:49 AM
git_it_rag's Avatar
the throttle should have a little play. IF the cable has no play it will cause it to do that. If not the cable, reset the pilot screw to 2 1/4 turns out from being seated. Loosen idel screw all the way. Start vehicle, warm up adjust throttle, than pilot to stall, than back 1 turn on the pilot.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
