800 sportsman won't start
Old Jan 26, 2009 | 04:44 PM
cfinley's Avatar
Default 800 sportsman won't start
I have a 2007 polaris sprotsman 800 that won't start. It only has 300 miles on it. Power works as I had to winch it on my trailer. The starter does not even click. Help me out if you can.
Thanks
Chris
I figured it out. It was my starter solenoid. The road salt ate it up. It was placed in a very bad spot the wheel well. The salt just destroyed it. Oh well $70 later
Old Jan 26, 2009 | 04:47 PM
700 sportsman's Avatar
I'd start by checking the fuses, grounds, and the battery cable connections
Also here is a link to the service manual, which may offer some additional help also
Good Luck
Old Jan 26, 2009 | 06:44 PM
G.A.S.'s Avatar
Have you checked to see if the kill switch is in run??? I did this once. COuld not figure out why the damn thing would not start turns out I slid the kill switch to off when I was washing it.
Cheers
G.A.S.
Old Jan 26, 2009 | 06:53 PM
jchunn's Avatar
I have no idea what your starter button looks like, but on my 95 sportsman, the starter button is on the left handlebar (thumb switch) and has to be wiggled and jiggled to get it to work. I have to push it in and then push it to one side, then the starter will engage. In other words, take a look at your starter button or whatever switch you use to start it (key or whatever). Probably not it, but worth a try before you pay somebody to look at it.
Old Jan 26, 2009 | 06:57 PM
JCDEYO25's Avatar
Do you hear your fuel pump cycle when you advance the key? Whoops...misread the part about the starter...Probably not the fuel pump...
John
Old Jan 26, 2009 | 07:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: jchunn
I have no idea what your starter button looks like, but on my 95 sportsman, the starter button is on the left handlebar (thumb switch) and has to be wiggled and jiggled to get it to work. I have to push it in and then push it to one side, then the starter will engage. In other words, take a look at your starter button or whatever switch you use to start it (key or whatever). Probably not it, but worth a try before you pay somebody to look at it.</end quote></div>
it starts w/ a key on the new models. no more buttons. when you turn the key on does it have power to the speedo display? when it turns on does the fuel pump cycle as mentioned? if it doesnt then, check to see if its getting power and if so most likely a bad pump issue. if it doesnt even turn over make sure the battery is fully charged and then start tracing power up though.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
