NEED HELP NO AWD 2003 400 sportsman
Old Jan 19, 2009 | 07:02 PM
TTJ88's Avatar
Default NEED HELP NO AWD 2003 400 sportsman
AWD WAS WORKING.PLOWED SNOW A FEW TIMES,EVERY THING GOOD.NEXT TIME PLOWING , NO AWD OR,LITE . AVERYTHING ELSE STILL WORKS(SPEEDO,GEAR INDICATOR ECT)
NO AWD FOWARD OR REVERSE ANY SUGGESTIONS WOULD BE APPRECIATED
Old Jan 19, 2009 | 07:05 PM
dave.570's Avatar
Default NEED HELP
check the battery, or maybe a ground wire.
Old Jan 19, 2009 | 07:08 PM
HIGHOCTANE's Avatar
Default NEED HELP
Give us some more to work with like year and model of machine for starters...
And welcome to ATVConnection!
Old Jan 19, 2009 | 07:38 PM
TTJ88's Avatar
Default NEED HELP
2003 SPORTSMAN 400. THAWED MACHINE,TOOK APART AWD SWITCH ,CLEANED ,HAS POWER TO SWITCH,CHEAKED FRONT END FOR BROKEN LINES WIRES.ALL LOOKED GOOD.BATTERY GOOD
Old Jan 26, 2009 | 07:49 PM
25083's Avatar
Is your speedo working? If it is not, the AWD will not work as it has a safety to make sure you don't throw it in AWD when it is revving above 3100 rpm.
Old Jan 26, 2009 | 07:58 PM
700 sportsman's Avatar
I'd say you busted your roller cage, in the front diff.
Jmuddin284
Jan 19, 2026 07:16 AM
velcro7279
Aug 24, 2015 01:15 PM
sweaver
11
Aug 18, 2015 03:47 PM
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
