Winch help
Old Jan 26, 2009 | 09:31 PM
Jpease's Avatar
Default Winch help
I have an 04 prairie 700. I just bought it recently from a friend. He told me the winch was replaced last year, but it does not work. When you push the up or down button, you hear a loud click. The click sounds like it is coming from under the seat. Any ideas??
Thanks in advance
John
Old Jan 26, 2009 | 09:54 PM
upnort's Avatar
Default Winch help
Most likely the solanoid. Switch operates that which in turn powers the winch. It should go to winch.
Old Jan 26, 2009 | 10:01 PM
Jpease's Avatar
Default Winch help
Thanks Upnort.
Is that solenoid under the seat and is it replaceable?
Thanks,
John
Old Jan 29, 2009 | 09:48 PM
KneeBone650's Avatar
Default Winch help
the location depends on the installer but it is usually under the rear fender in the wheel well, it needs air so it doesn't overheat during operation, and yes it is replaceable. what name brand is the winch, mile marker is known to have a weak solenoid but they recently upgraded it.
Old Jan 30, 2009 | 08:28 PM
Hayashi's Avatar
Default Winch help
<div class="FTQUOTE"><begin quote>Originally posted by: Jpease
Thanks in advance
John</end quote></div>
Solenoid is aka CONTACTOR by some winch brand such WARN. In contrast to some other poster, when it goes bad, sometimes it doesn't make any noise because it has gone bad! Other possibility is the locked up winch motor. Apply 12 V directly momentarily to the winch motor and see if it turns.
If motor turns, the solenoid/contactor is bad.
If motor does not turn, then he motor or gear mechanism has gone bad.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
