2001 trx 350 es
does anyone know if you can convert the electric shift to use the manual shift. does honda make a kit or anything like this ?
i have had my 2001 trx 350 es for about 4 months and have nothing but problems with the shifting on it i have put a new shift solenoid, and am going on my second angle sensor and i am pretty much sick of f#@$%g around with it
thanks
thanks
On the TRX350 the main engine difference is that 1 of the clutch discs are different so there's no need to change it .. I would take off the shift motor and remove the reduction gears , then reinstall the shift motor , this will help keep water out of the engine ... As far as the shifter you can either replace the shift shaft with the FM shaft or weld the shifter onto the orginal shaft ..
