2001 trx 350 es
Old Jan 27, 2009 | 06:11 PM
moparpuggle's Avatar
Default 2001 trx 350 es
does anyone know if you can convert the electric shift to use the manual shift. does honda make a kit or anything like this ?
i have had my 2001 trx 350 es for about 4 months and have nothing but problems with the shifting on it i have put a new shift solenoid, and am going on my second angle sensor and i am pretty much sick of f#@$%g around with it
thanks
Old Jan 28, 2009 | 05:26 AM
HondaMechanic's Avatar
On the TRX350 the main engine difference is that 1 of the clutch discs are different so there's no need to change it .. I would take off the shift motor and remove the reduction gears , then reinstall the shift motor , this will help keep water out of the engine ... As far as the shifter you can either replace the shift shaft with the FM shaft or weld the shifter onto the orginal shaft ..
Old Jan 28, 2009 | 08:42 AM
thanks for responding
so if i just welded a shift pedal on to where the shaft is i could use it in manual?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
