Polaris trailblazer starting issues!
Old Feb 1, 2009 | 10:25 PM
quepasa69's Avatar
Default Polaris trailblazer starting issues!
I have a 98 250 polaris trailblazer....when I start it after its been sitting for a while I have to hold the throttle wide open for a while then it finially turns over. If I shut it off and re start it starts right up, no problem. Then after a while again, same thing...I am thinking there is an adjustment needing made to the carburator. If I choke it it will never start, only if I hold the throttle open. Any ideas is appreciated!!
Old Feb 2, 2009 | 05:57 AM
ftwflh's Avatar
It most likely needs a fresh topend job aka piston,rings and a bore job.Check the cold compression before messing with the carb
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
1000gade
May 27, 2015 12:37 PM
