500 ho problem
Old Feb 2, 2009 | 05:55 PM
fishguts's Avatar
Default 500 ho problem
this weekend i was going up the lake in quite a bit of snow and starting loosing power, it lasted only a few mins and went away. i got to the fish shanty and put in some dry gas. seemed to run fine, then on the way home i started again to loose power and it got bad. i could barely get enough power up to move. idles fine but try and give it much throtle and it just bogs out. any sugestions to help me get this going?
Old Feb 2, 2009 | 06:05 PM
fishguts's Avatar
i forgot to add its a 04 atp, and with half choke it has quite a bit more power.
Old Feb 2, 2009 | 06:28 PM
<div class="FTQUOTE"><begin quote>Originally posted by: fishguts
i forgot to add its a 04 atp, and with half choke it has quite a bit more power.</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] With choke on runs better, is usually a sign carb jets stopped up,may need to check out and also check fuel filter and flow.
Old Feb 2, 2009 | 06:37 PM
fishguts's Avatar
thanks for the reply. the flow was very low, my brother has a pump deal were you can like pull a vac on the line and suck stuff out. did that and blew through the line, it seems not to be blocked but the gas still only comes out real slow?
Old Feb 2, 2009 | 06:53 PM
thanks for the reply. the flow was very low, my brother has a pump deal were you can like pull a vac on the line and suck stuff out. did that and blew through the line, it seems not to be blocked but the gas still only comes out real slow?</end quote></div>
Disconnect fuel line to carb and crank up,if fuel flowing I would still check carb if still running bad. Fuel flow wont be a great amount even if pump ok,just works enough on vacuum to keep bowl full,not like an electric pump!
Old Feb 2, 2009 | 07:03 PM
fishguts's Avatar
aok thanks again.
Old Feb 6, 2009 | 10:09 AM
fishguts's Avatar
thanks again guys, it turned out that it was cattail fluff in the airbox and carb did it. got that all out and she runs like a top, got new duros coming for her now. heres a pic of her.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
