RCR Stage 1Kit for Xplorer 400
What all does it consist of? If I were you I would buy a hpd pipe and a spark arrestor muffler. Buy the delta v-force reed cage, k&n filter, and clutch kit from hot seat performance. The airbox mod is just drilling one more hole in the top of the airbox between the other holes. You can also drill holes in the inside of the airbox on the plastic piece that goes around the filter. That piece helps water pass around the filter. If you ride in a lot of water and have no snorkel then you might not want to do that then.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
