RCR Stage 1Kit for Xplorer 400
Old Feb 9, 2001 | 12:39 AM
Xpress3002x4's Avatar
I'm thinking about installing this kit on an '00 Xplorer. Any one have any experiance with this kit on an Xplorer?
Old Feb 9, 2001 | 12:46 PM
MEANGREENMACHINE's Avatar
What all does it consist of? If I were you I would buy a hpd pipe and a spark arrestor muffler. Buy the delta v-force reed cage, k&n filter, and clutch kit from hot seat performance. The airbox mod is just drilling one more hole in the top of the airbox between the other holes. You can also drill holes in the inside of the airbox on the plastic piece that goes around the filter. That piece helps water pass around the filter. If you ride in a lot of water and have no snorkel then you might not want to do that then.
Old Feb 9, 2001 | 04:28 PM
CajunDuckman's Avatar
I have the equivalent of somewhere between a Stage II and III from RCR. I love it and have a hard time keeping the front tires on the freakin' ground! I'm figuring I have somewhere around 50-53 hp.
Old Feb 11, 2001 | 05:48 PM
Bill.Ciliberti's Avatar
The HDP pipe will NOT work on the 00 400cc Xplorer.I had to send mine back to Rick Ritter.The shifter is in a differant location on the 00 model Xplorers.Im still looking for the correct pipe to fit my Xplorer?
Bill
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
