2007 Rincon noisy when starting only 250 miles
Old Feb 9, 2009 | 09:04 PM
mike h's Avatar
Default 2007 Rincon noisy when starting only 250 miles
My 07 Rincon is really noisy at the gear area of the starter when starting. It seams to be getting worse. Has anybody had any problems with the starter clutch, torque limiter or other related parts? I took the starter off and spun it over with the switch button and it is quiet and works fine. The gears inside the housing look good and rotate OK by hand. It starts fine but is noisy. What could be making the noise? Is it normal? It sounds like the normal sound that you here when you spin the starter but louder and it seems to continue for a bit after you let off of the button.
Old Feb 10, 2009 | 01:21 AM
JeffinTD's Avatar
Welcome to the forum.
I'm not aware of any known problems with Rincon starters, and mine doesn't make any funky noises when starting.
Is the machine still under warranty?
Old Feb 10, 2009 | 10:38 AM
mike h's Avatar
It is out of warranty. It is the normal whining noise that you here from the starter when cranking but has gotten louder. Looking at the manual and it looks like something in the front engine case where the torque limiter is located. I am going to take it to the Honda shop and let them listen to it. I'm hoping that it is normal.
Old Feb 10, 2009 | 10:48 AM
JeffinTD's Avatar
Yeah, kind of hard to diagnose w/o hearing or seeing it.
If it's gotten significantly louder, though, I'd think that would be a sign that something not normal is going on.
Maybe one of the experts here will chime in shortly.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
1000gade
May 27, 2015 12:37 PM
ecorman1
8
Dec 11, 2000 09:33 PM
