2001 scrambler 50
Old Feb 11, 2009 | 10:25 AM
KRL's Avatar
KRL
Default 2001 scrambler 50
hi I am new to the forum and am looking for some help. my 50 scrambler will not start i have had the carb off and cleaned. the wheeler is in great shape and has been took good care of and the electrical system has been checked out fairly well also. i am hoping that someone out there has had this problem and could maybe shed some light on it. any reccomendations will be greatly appreciated!
thanks in advance!
Old Feb 11, 2009 | 11:03 AM
Kerbbirds's Avatar
Does it have spark ? Take the spark plug out and ground it to the engine and turn the engine over and see if the plug sparks, check for compression while your at it, get a compession tester and put in the spark plug hole and turn engine , should have at least 100 psi, if it has spark, compression and is getting good , clean fuel it should run.
Old Feb 11, 2009 | 08:00 PM
<div class="FTQUOTE"><begin quote>Originally posted by: KRL
thanks in advance
If has spark,carb clean,but wont start,you can block off air box tube with your thumb and see if it starts! I have to start a bunch like this since electric choke sucks! Even the newer ones with manual chokes some times have to be done the same way. By blocking air inlet tube, forces fuel into engine better on start up.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
35dodge
Sep 29, 2015 09:40 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
