300EX problems
Old Feb 12, 2009 | 06:03 PM
juttin_15's Avatar
Default 300EX problems
my 1996 honda 300ex is given me trouble, when it would crank it would only run choked when you hit the topend it would bog when you would let out it would rapidly backfire, now it wont crank, it fires, but i cant oull the spark plug so i dont know what it looks like, the jet is not clogged, the rocker arms are gapped to the thousandth, it was timed to perfection, i dont know what to do i am fixing to stop puttin money in it and ebay it, any suggestions.
Old Feb 12, 2009 | 07:49 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Sounds like it was running extremely lean if it would only run with the choke on.
You say you can't pull the plug, do you mean you can't get it out? If that is the case I would guess that it got very hot due to running lean and has burned up the topend.
Old Feb 12, 2009 | 08:04 PM
juttin_15's Avatar
no, i lack the proper socket, it will turn over fine, it isnt locked up, there isnt any rattling, the rockers are tight
Old Feb 13, 2009 | 09:40 AM
Pirate Biker
Limping Rider!
If it doesn't run unless you have the choke on, it is running lean, either from an air leak in the carb boot or the wrong jetting.
Get the correct socket so you can remove the plug and check it.
Old Feb 13, 2009 | 11:29 PM
Wrenchnalldatime's Avatar
Did u check the pilot jet too? Or just the main jet? I would take the carb apart and clean it all and I mean every passage. that should cure your illness
Old Feb 15, 2009 | 11:58 AM
juttin_15's Avatar
the spark plug is soaked in gas but it is firing, i pulled the float bowl and the jet in there, where are the other ones
Old Feb 15, 2009 | 12:10 PM
300exStroked's Avatar
Pilot jet is right next to that up in the hole.. small flathead should be able to get it out.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
