polaris reverse
Old Feb 14, 2009 | 08:54 AM
speepdaedeesi's Avatar
Default polaris reverse
02 scrambler 400 2wd
reverse only works when i hold down the yellow button on the handlebars. is it supposed to be like that:?
Old Feb 14, 2009 | 09:00 AM
theCATman's Avatar
If it has a higher than stock primary spring OR a full clutch kit.... yes. If it's all stock then no, it shouldn't.
If it's stock & doing it, that possibly tells me that the belt is worn alot allowing the engine to rev high enough to engage the limiter in reverse.
Old Feb 14, 2009 | 09:19 AM
i got it used, and it was really well taken care of, so im not sure if its stock or not.
if i try to back it up in reverse without hitting the override button, the motor bogs down, then backfires, then dies
what should i do
Old Feb 14, 2009 | 11:55 AM
eggenz7's Avatar
unplug the black wire on the rpm limiter.
Old Feb 14, 2009 | 12:11 PM
wheres the rpm limiter? is that the button im having to push to get it to move in reverse?
Old Feb 14, 2009 | 12:39 PM
eggenz7's Avatar
there is a box usually under the hood piece on the front of the machine. should have ablack wire running to it. that will disable it and not require you to use the yellow button
Old Feb 14, 2009 | 12:52 PM
thanks.
the way it was explained to me from the guy i got it from was...
it will go in reverse without pushing the button, only just slowly.
to go in reverse fast, you have to push the button.
so i was thinking it was broken because it only went in reverse when pushing the button.
Old Feb 16, 2009 | 06:08 PM
ok i got time to look at it today. i took off the hood, and i see one place where it could be.. but i dont want to cut the wrong wire. there was no connector, so it looked like i would have to just cut the wire
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
maxjung
Jul 13, 2015 05:11 PM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
