4x4 light flashing 4 times, oil cooling fan turns on with key
Old Feb 14, 2009 | 07:00 PM
DRINK's Avatar
Default 4x4 light flashing 4 times, oil cooling fan turns on with key
I have a 02 Honda Foreman S 4x4. I lent it out and it was returned with problems. I need help. Problem #1 the head lights do not come on. The display lights for the speedometer work just not the head lights. Problem #2 the oil cooling fan turns on instantly when the key is turned on and does not shut off. Problem #3 the 4x4 light is flashing 4 times. Problem #4 the battery is dead.
Does any one know what the flashing 4x4 light, 4 times indicates or where I can find indicator codes? And how to test the thermo sensor or troubleshoot the cooling fan? Could these problems be related to the battery???
Old Feb 15, 2009 | 12:29 AM
Gimpster's Avatar
Sounds like something got awfully wet.
The 4 code is power failure
I will double check my manual when at the shop to be sure
Check all the fuses and connectors at the ecm, voltage regulator and handlebar switches for moisture.
----- Gimpster -----
Old Feb 15, 2009 | 08:15 AM
JeffinTD's Avatar
You mentioned the battery being dead... You might start with a good, charged battery and go from there.
Old Feb 15, 2009 | 09:38 AM
DRINK's Avatar
All the fuses under the seat were good, and the new battery did not solve any of the other problems. It cranks up fine and idles ok but I have not road it. when the key is turned on the cooling fan turns on instantly. And the fans RPM increases and decreases directly with the engine idle/throttle. I do not leave the new battery hooked up for fear something may have shorted out the old one.
Old Feb 15, 2009 | 03:56 PM
JeffinTD's Avatar
Have you checked the connectors, especially for the ECM and voltage regulator?
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
VascoConroy
Jun 12, 2015 10:30 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
